Hi all
I've recently come into a little cash, and I'd like to upgrade my aging machine to something more modern.
This is my current rig:
Shuttle SN45Gv3
Athlon XP 3200
1gb Crucial PC3200
Asus GeForce 6200 AGP (recently bought when my R9800XT died
Obviously it's a bit long in the tooth.
I've been eyeing shaffaaf27's £500 tower over here: http://forums.overclockers.co.uk/showpost.php?p=11840938&postcount=3
..and I noticed a few changes this week from the one published last week. I wonder if anyone can answer these questions:
1) Why the change in cooler?
2) Why the mobo change? The Gigabyte from last time is only slightly more expensive, and gets lots of good reviews on OCUK
3) Why the Radeon 4850 change from Gainward to Powercolor? I can't see any discernible difference in specs, and IIRC Gainward is a more respected brand.
4) Is the Q6600 worth the extra cash for two extra cores?
There are a couple of points I should make about my ideal setup and my usage:
1) I will be running XP and Ubuntu (not Vista), so that might affect the amount of RAM I want/need. I don't know much about this though.
2) I don't need an optical drive cos I've got an external LG USB supermulti drive which will do absolutely fine.
3) Ideally I'd like it to be as quiet as possible, within my given budget. My machine has been stupidly loud because of its small size and the heat the PSU generates, so I'd really like relative quietness to be a part of my upgrade.
4) My budget is ~£400, up to £500 at a push.
5) My uses are general browsing, some coding (pretty low-intensity stuff) but I'd also like to get into gaming again, so all the Source games, and some more modern stuff would be cool too (would particularly like to play GTA IV when it comes out!). I read some HD 4850 reviews and it seems pretty solid for current gen games and the near future so it seems like a good bet.
6) I will be using my 19" WS LG monitor (1440x990) for the foreseeable future.
I've been out of the hardware game for a couple of years now, and things have moved on quite a long way since I kept up with it.
Any help on this would be much appreciated!
Shuttle SN45Gv3
Athlon XP 3200
1gb Crucial PC3200
)Obviously it's a bit long in the tooth.
