OCuk Custom Builts
13 Aug 2006
Hi guys,
Planning on get a new build and read on Ocuk that they will build custom systems (you need to give them a call for this). I was just wondering if I can totally customise the pc this way or will I be limited to their choice of components?
Cheers!
Yes if you call sales, they will put you through to someone regards a custom build. You pretty much have full reign though advice on suitability of components will most likely be offered.
Sales - UK 0870 443 0880
Thanks for the quick reply. Will I get the standard 1 Year warranty aswell with the build? Is there an option for extended warranty?
Cheers!
However don't forget it's likely that a lot of the individual components will carry their respective manufacturer's warranty. :)
Interesting, i called them yesterday and was told they can do the modifications to their base systems as listed on the PC builder, but don't do custom builds?
Well I guess that is custom really, as their base systems go through the whole spectrum of prices, and the variations on them (as on the site) are quite large. :)
