- 1 Mar 2008
- Near Longleat, Raaaar!!
Picked up a used E6300 from a well known auction site. At stock it idles at about 47-49c and rises to about 54-56c under load (temps from Coretemp)
I heard they overclock well so I tried 2.4 and the temps rose from about 53ish idle to 65c+ under load using orthos. The thermal spec according to intel is 61c max and the cooler i'm using used to keep a q6600 under 65c at 3ghz.
I've tried reseating the cooler and reapplying the TIM but not much of a difference, maybe 2c or so.
Now, Have i just bought a duff chip which has probably been overclocked to an inch of its life by someone who doesn't worry about temps or are they OK to push above 61c?
The rest of the system it in is:
Abit FP-1n9
3 gig ram
Akasa AK-956CP cooler
xp
Xpertvision 8600GT DDR2
Abit FP-1n9
3 gig ram
xp
