 - 28 Oct 2006
 - stoke on trent\bromsgrove
Hi all
Right I woke up this morning & looked at my money & thought sod it I am going to buy something!
So I went overclockers & got this lot MMMmmmm =
Zalman Reserator1 v2 Fanless Water Cooling System
& with 2 Litres of Feser One UV Reactive Coolant (Blue)
So after a hour of building it & installing it with 30 min’s of leak testing, it was on !!
I am only cooling the cpu as the Zalman ZM-GWB8800 Ultra/GTX VGA Water Block is some £54 i can not spare at the mo..... .
so the temps are looking better thank god as I would say they have dropped about 7c to 8c less.
I am using AS5 so i have to wait about 180 hours for that to wear in i am told.
Plus I am thinking what to do with the 4x 120mm side fans on the cm 830 stacker? So I keep them on full (1200rpm) or not use them ?
Well I am thinking i might in a few days try some more over clocking & see what happens..... .
I am not thinking this water kit will do god like things but it must help a bit.
also i have the cooler wired in to my UPS as if the mains goes off the cooler would go off but the pc would be left on ! Not a good idea I think.
But is there any way I can start the cooler with the pc, Instead of a switch?
Any idea folks what might help me.
 im such a nerd.
 on the flip side with the on/off separate you can leave/start your loop running for 10-20 extra seconds to stop shutdown/start up heat stress of the chip.
