Super Stardust HD Team Expansion
Ill probably get it tbf, could be quite cool, the normal co-op doesn't work at all! + I think thats the final trophy for platinum, not that im a ****.
ill most likely get it, anything stardust related should be immense :p
any news on uk release date?
and also containing the last trophy is also a small bonus :D
Wow, even at £2.99 this was a massive waste of money/it should have come as an update. The only real new thing is split screen co-op. There is another mode where players (on same couch) can vs each other in games like CTF, but I know no one who would be able to challenge me ;)
The new orchestral sound track is awesome though :)
I was immensely disappointed. Split screen coop is actually inferior to the non-split screen imo. In non split screen you have to communicate and work together to stay alive and it becomes incredibly exciting when a huge wave of aliens land and you're shouting commands at each other. In split screen you can just run off on your own which while easier really takes a lot away from the teamplay element.
The music is good but not worth the money.
Side note: I'm dead upset, my housemate was finally beginning to get good at the game in coop but uni has finished and hes moved back to bath :(. There goes my chances for a coop high score.
the mutiplayer vs. thing looked really cool, but none of my mates like sshd :(.
classic co-op is seriously messed up because of the camera... it just feels to weird and boosting is like suicide! split screen co-op seems better to me but it takes a massive frame rate hit :(
Did you manage to get the trophy? & is it hard?
Yeah we did, as ojste mentioned it was easy. At first we were going for it aggressively, trying to take out everything we could while sticking close together for the weapon boost, problem was either one of us would die or we would stray too far from one another thus breaking the weapon boost, the low FPS given by split-screen makes segomo really difficult. But then we figured out the UFO attacks are triggered by us attacking the asteroids and all we really had to do was stick together and dodge the 5 large asteroids for 3 mins, totally doable even if you were using a hand to control each ship.
All you really need is 2 controllers, the expansion and to have unlocked segomo in single player, you don't even need a friend to help you.
Ok thanks. Ill probably just get it to see what multiplayer is like anyway, as I didnt get on with single-screen at all. You kinda wanted to go your own way but couldnt so gameplay kinda stops, it just didnt really work tbf.
Well you'll love the split screen then. Problem was me and my mate got used to having to stick close so we would shout at eachother which way we were about to go and stick together like glue. Splitscreen then became pointless for us as we had worked out at routine that worked fine in single screen (and was beginning to yeild a decent amount of points, shame the git had to go back to bath cos we could have got some amazing scores in a few months).
