New build Q6600 question
3 May 2007
Nottingham
Hi my birthday is coming up soon and my fiancé had kindly offered to buy me a new build.
here is what i would like to get.
Mobo:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-241-AS
CPU:
http://www.overclockers.co.uk/showproduct.php?prodid=CP-211-IN
Ram: (going to add another set to make 8gig when i have more money)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-069-GL
i saw that the CPU says it can be overclocked to 3.30GHZ i was just wondering will the motherboard i chose be able to overclock it? and also does the motherboard have wifi built in? (not to bothered would just be a bonus)
and Finlay i saw that it is recommended i get a better heat sink if i intend to overclock it, can anyone recommend one
That board will overclock it to 3.3Ghz.
The board does have WiFi.
And i'd reccomend a Tuniq Tower, Scythe Ninja or Thermalright Ultra Extreme.
Mobo:
CPU:
Tuniq tower or watercooling kit
I used to have that board and had my Q6600 running at 3.6Ghz happily - its a good board. Tuniq tower or Arctic Freezer 7 Pro will do.
If you just get a retail Q6600, rather than the "guaranteed" one, then you can afford a tuniq tower. Pretty much every 6600 G0 will hit 3Ghz at least. You would be better off with the TT.
