I've been having a general fiddle with my system and have came to the rather obvious conclusion that the main thing that produces heat in my system is the darn 8800GTX. It's stock cooler keeps the actual card temps ok but even with exhuasting heat from the rear, there's a hell of a heat that radiates up to my CPU cooler... I've been thinking about making some sort of thermal padded sheet to partition the 8800GTX off all together, that way no heat will be able to radiate upward to the cpu and chipset. Anyone else ever tried that? I was gonna make it so the side fan blew air only to the GTX's compartment and put an exhaust fan in the unused PCI card slots at the rear of the case. I have good overall air flow in my case but dispite that, tipping my case on its side (so its like a desktop) and taking the side pannel off drops a good 5-6c off all my temps (bar hard drives)
The alternative is to look for an aftermarket cooler that will shift the heat faster, or perhaps even go down the watercooling route. I could watercool the CPU & North/South bridges and then it would be irrelevant what heat came off the GTX.
Any idea's?
Any idea's?
