No, it's fine-I've done it with my E4500. As long as you don't get to the stage where you need to up the voltage it should be OK. I've hit 2.9Ghz stable with it.
So basically a no no with my existing amd cooler?
You can overclock on stock cooler, but it's not recommended, because they are not good with temps especially when upping the volts
likely to shorten the life of your chip as well!
73C MAX > Intels info on their C2D.
Thats not to say you are to run it at 73C 24/7 as there is no need to reach that temp.
You pay a lot of cash for a good CPU, spend £15-30 on a good Heatsink to go with it.
Stock Heatsicks are crap and loudish, for £15 a Artic Cooling Freezer is far better but it will limit OC'ing as its 90mm and loudish at full speed, best go 120mm Cooling.
@ Buckster, What are you talking about ?.
Who the hell has a Case Temp of 73C, the Amb for them Intel readings is 22C.
Visit the Intel site and learn its 73C, that's not to say it Throttles at 73C, thats the MAX REC Temp (we all know about Tcase etc and the readings are all messed up for 45nm CPU for now).
Anyone that cannot cool a CPU to below 73C needs overhaul there cooling and if you see 73C Socket/Diode in any APP that's hot.
Encouraging peeps to cook their CPU as you only keep yours 2 years is not good advise, if you want to OC invest in a proper Cooler.
