Best CPU waterblock?
it looks exactly the same to me except the base is stepped which doesn't really have any effect on cooling I don't think...
http://www.xtremesystems.org/forums/showthread.php?t=198815
That's the XSPC Edge V2 - even says so in the title of the link you provided :p
aka Acetal version
Not seen any photo's of the delta V3 yet
Edge V2 looks exactly the same as the Delta V2 except:
1) It is black
2) It has the 'channels' of the edge instead of the 'pin grid' in the Delta.
1) It is black (Acetal vs metal)
so material and design then - not to much ;)
Sorry couldn't help myself. I do know what you mean but those two differances are worlds apart in block design. But yes the Delta V2 and Edge V2 both use the same retention bracket and therefore have simular profiles.
Edit: The Edge V2 also has a stepped base (as said above) with the Edge V1 and Delta V2 don't.
Oddly enought the Delta and Edge have very simular graphs see here and here but they are different due mostly to the pin/channel design. Material affects corrosion/opperatonal temp range/apparance etc -
That is the universal bracket in all fairness. the quick mount bracket is a lot sleeker. I change blocks a bit though, so didn't really want to have to keep removing the motherboard every time to do so.
Amen to thet........it's a pain taking the MOBO out!!
Indeed :D
Was refering mainly to the shape and appearance however.
The block shape and mounting bracket etc is exactly the same as the Delta V2.
It's like they took a Delta V2 and put the Edge internals in it.
Which I don't mind at all as the Delta was a lovely block.
