Courtesy of Seth (owner of an awesome Hillman Minx wagon daily with DIY coilover conversion, trick wheels and perfick stance) on RR, thread here.
*n
So a couple of weeks ago forum member Skinny started this thread on Lace paint. While I had pretty much worked out what I was going to do on the rest of the Minx's bodywork I had been having trouble deciding what to do on the roof. Being a wagon there are ridges in the panel to give it some stiffness but these make any paint design tricky as it wouldn't look right if it crossed those lines. That thread reminded me of lace work and made my mind up! Lets have a go. How hard can it be?!
I spent some time looking at the pictures in the thread and any others I could find to see what I liked and what I felt "worked" and why. I also knew I wanted to use the same green with gold flake paint I used on the wheels. A few trials on a couple of scrap Herald doors (the first using a paper doily before the lace turned up) and my desire to keep it subtle rather than lairy led to the use of a grey/green base colour before applying the lace. This would result in a more time consuming process but I felt the results would be worth it.
Eventually a day came that looked like it would be dry and not too breezy considering the outdoor location of my "spray booth" First to mask was the outer border of the base coat that would also be the extent of the lace-work.
The tape is 1/8" (3mm) 3M Fineline and while it does go round quite tight bends I was pushing it a bit hence the slight ripple on the inside radius. These were later flattened by cutting the tape with a sharp scalpel at each ripple and pushing it flat.
At the back of the roof there were panel lines to follow for the curves but at the front I had to use something to mark the corners to keep a consitent radius
I also drew guide lines so the front ends of the panels copied the curve of the top of the windscreen.
I used a ruler all round while laying the tape to make sure the lines were parallel and eye-balled along the length of the roof to check for straightness of the long runs, correcting as necessary. Unreeling a length of tape and then pulling it taught while lowering it towards the car helps get the lines pretty straight at first attempt.
Once the outlines where in place it was easy to lay more tape and newspaper down to fill in the rest of the masking. At the ends of the roof wide tape was layed over the boundary line....
..and then a scalpel used to cut through this down the middle of the fine line tape. The waste then peeled away.
That is the method I have always followed in the past when masking the flames on other stuff/cars.
With more newspaper applied the spray booth was pretty much ready for paint. I used 1500 paper to key the original paint being careful not to damage the edge of *** masking. It was then wiped down with several goes over witha tack clothsome kitchen roll.
First to go on were two coats (first one pretty light as per photo) of Ford Forest Green Metallic. This was to act as the background colour of the lace.
This paint was going to have to withstand some masking tape over the top and while my test panels had shown that it wasn't pulling up even if the tape was applied as soon as it had got touch dry I opted to leave it an hour before continuing.
*Tea break*
*n
