As I stated, there's a big difference between a single commuter and a fast road group working together...
I cheated a little really because its actually a readout from www.bikeroutetoaster.com , i can get the same data off my gps thingy...but its in the other room and im too lazy to go and get itWhat comp are you using, pc input?
Yes, elevation above sea level in metres.Elevation above sea level?
I ride alone most of the time and I can manage somewhere over 20mph on rides of 30-45 miles and then my speed starts to tail off. 30mph for 90 miles, even with the prevailing tail wind on that route, does seem a trifle high to me. If you are doing that, even as part of a group, then you are very fit and should possibly consider a career change in time for 2012?
Either that or he needs to set the blooming thing up properly!I think Platypus needs a new computer for his bike that's for sure.
Seems fine when I use it for running/rowing.Either that or he needs to set the blooming thing up properly!
