Permabanned
- 20 Aug 2008
dtek fuzion v2 is the way forward
Isn't the Cuplex XT Di 775 G1/4 the better water block with the right pump.
It proberbly wouldn't perform any better than the GTZ or Supreme if they all used the same powerful pump, I'm not sure though, but I've never seen any tests that show the cuplex performing better than those blocks with a powerful pump. There's nothing much between the blocks anyway, they're all basically on a par (fuzion, gtz, cuplex di, supreme) with less than a degrees difference between them, you're best off getting the one you like the looks of most.
Questions
Are two pumps in series dangerous... or can it ever become dangerous with pumping the liquid too fast? Sorry for the n00b question. lol
But what are the benefits? Surely your limited by the barb size as it will restrict the flow no matter how fast/hard you pump the water?![]()
What pump would be suitable then please?
Until the GTZ has been proved to not have the same problems as the GTX, I wouldn't touch it with a barge pole.
I'd rather have something wired up to the psu lack of confidence on my part, so to pumps would be safe then?
If you use an 18W DDC or a D5 you'll get results almost as good as anything else, but if you want a really oomphy pump, you're really looking at a 240V mains powered one.
would using two D5's make a difference?
overkill for most setups though, if you didn't have a couple or more radiators and extremely restrictive blocks you'd be hard pressed to notice the difference in temps from one pump.
I think the top is acetal, so it should be OK. I still wouldn't buy one though![]()
What happened with the GTX model like?
