Nehalem won't be much more effective for games clock for clock according to the first reports, no better integer support, higher latency on caches etc. If AMD optimizes to beat Intel clock for clock in games, it will be fine as long as it can get 3Ghz+ chips out there a bit cheaper than Intel's.think AMD is highly likely to destroy intel.
Businesses and home users DO not overclock, and currently AMD is still as good if not better clock for clock compared to current intels.
Considering that AMD will be cheaper as they dont need an entirely new system and only replace the CPU, its far cheaper and great performance, with intel they will need to change everything and will cost more than just the processor..
Whatever company goes for the more expensive solution is just not run well or retarded
I think they should just whack some 4870 cores on top of each other and solder them to a cpu socket....will work just grrreeeaaatt![]()
Maybe in server code but games love Core2's big and fast L2.and currently AMD is still as good if not better clock for clock compared to current intels.
Some utilities can use the gpu for workload now, physics calculations, increasingly your idea might not be so silly![]()
http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=3272&p=12
(Nehalem's small L2 is reason why it won't be such jump forward in game performance compared to Core2 architecture)
Cheers for the link I didn't realise the Nehalem was going to be a bit of a backward step for gaming. The 32nm are also a long way off.
The problem with saying things like that based on gut instinct, assuming you don't work for AMD designing their cpus?, is that you can be made to look a fool if it turns our not to be true.
I remember people saying the same thing about ATI before the 4850 launch. Look how many people had to eat their words then?![]()
