I'm not sure I understand what you mean!is there any disadvantage in buying 2 separate 1gb sticks of ram instead of a kit on some sites I've seen 1gb less than half the price of the equivalent 2gb kit. Cheers.
I'm not sure I understand what you mean!![]()
If you go 64bit make sure you use more than 4gigs or RAM!
It's cheaper to buy two individual 1GB sticks rather than purchasing a kit.
But then you've no guarantee that the two sticks will run together.
if you've already got 2 x 1GB sticks does it matter whether you then buy say 2 x 2gb sticks on top of that as an upgrade? and is it better for them to be the same ram as the original?
How will having 4 sticks of 1 gig perform?
cheers (sry for slightly hijacking the thread with my questions)
