you will be limited to 1080p max
Could anyone tell me if it is possible to connect a playstation 3 to an apple cinema 20' display? Do I need a HDMI to DVI cable?
Thanks
No, 576p, 720p, 1080i and 1080p (1920x1080)PS3's can't output higher than 1080p anyway, can they?
Computer monitors usually have a different native resolution meaning the imgae will almost always be scaled which can look bad depending on the LCD used.
I assume that is aimed at the OP? (I have a Sony 40W2000 LCDBest to try and save up for a cheap HDTV if i'm honest.
