Is anyone still using this board? I've just whipped a spare machine together using kit from my Ghoul-Box and I have ended up with psychedelic socket 939 mono-core system!
I'm pretty familiar with Socket 939 Athlon 64 but I always used boards from the ASUS A8N-Series so this DFI board with it's freaky BIOS has blown me away a little!
I wondered if anyone still uses this board can you throw me some general tips. I'm having trouble clocking a Venice 3200+ to 2500MHz which it can do with ease on the previous A64 boards I've used it on?
I am using a 1GB set Corsair Twinx1024-4000Pro which I picked up from v0n @Members Market so in theory that should be able to run 250MHz (DDR500) but the sticks are currently uproven.
The problem I am having is I am unable to boot to Windows once I start overclocking? it's like I am losing my SATA disks for some reason? I have changed the HTT link from x5 to x4, slackened the memory and given both the memory and CPU more voltage than I think they need. Is there some option for locking the PCI BUS or is that automatic? Does the HTT link and chipset need a voltage boost also for just 250MHz-FSB?
I think I will try and work out how to drop the memory divider and keep that running at 200MHz (DDR400) as that seems to be working fine. .
Man what crazy BIOS
lots of cool options in there though and I will work it out in due course hopefully. Anyways these are the main BIOS screens as set up for stock use, all I have adjusted is the memory timings . . .
Thanks in advance for any pointers, I've got a week or two with this board so it would be good to tweak it a little and see whats it made off, everything is working nicely at stock so it would be nice to get the old Venice running at's its 2500MHz-2600MHz comfy overclock speed!
