hahaha what a fight
i go for gibbo due to him not using crappy matx
however its nice to see a good matx rig.. id have gone a diffrent gpu than the 4870x2 due to there heat unless you can get a decent cooler on it in the case?
Yewen - ditch that Zalman for a Scythe Mini-Ninja at the very least, as that'll give you some more cooling, but you should seriously consider moving up to a Lian Li PC-A05 so you can go CrossfireX.
And why no water cooling? 2 or 3 Swiftech 80mm radiators coupled to an ApogeeDrive unit would all fit in fine.
I'll be in on Monday morning to discuss what progress has been made on this...![]()
It is by no means the finnished spec.
You can come but you will be on your own.
Sunday.![]()
well just leave the keys![]()
Ok guys as Gibbo is doing his usual and going for brute power I have gone for the stealth OMG HE DRIVES A SPORTKA aproach.
Here is rig one which is complete and under going massive stability testing.
SILVERSTONE SUGO mATX RIG!
Intel E8600 3.33GHz @ 4.50GHz (1.42v)
Zalman 8700 low profile CPU cooler
Asus P5E-VM HDMI Intel G35 Micro-ATX (Socket 775) PCI-Express DDR2 Motherboard
Cellshock 6400 2GB (4GB Total) memory 4 sticks @ (roughly)850MHz 5-5-5-15
ATI HD 4870 X2
300GB Velociraptor
At the moment my PC is upto 22,000 3D 2006 but I have the card clocked and Gibbo has not done this yet. That said considering it is a cheaper rig than Gibbo's AND in a micro ATX form factor I do not think I am doing that badly.
Bring on the quad crossfire Phenom rig!![]()
The Sugo is a bad idea as it cannot get rid of the heat from a high end rig. The cooling on them is very poor. We have been trying to help a guy out with one and a terrible heat problem. 105 degrees C on the cpu!! By making some changes he got it down to 50 odd degrees at idle but that is still too high. There are better mATX cases than the Sugo. I would'nt buy one of those rigs and i certainly would'nt be selling one. With that spec it has a high chance of warranty returns due to heat.
My moneys on Spie
are you going to run intel burn test?
http://forums.overclockers.co.uk/showthread.php?t=17911268
When did the Abit IX48-GT3 come into stock?
yewen if you win, ill come over and give you a kiss![]()
