Anybody Good With Head Units? Settings Not Being Stored....
19 Oct 2002
Jupiter
Hi all,
Had this problem with the 206 for a while now.
In short, the head unit keeps losing any settings that i set/change/store.
Simple solution is usually to swap the Red/Yellow wires around on the ISO loom, so i have done that, and it still doesn't work.
Peugeot supply an ISO adapter for the 206, so i bought that hoping it would cure it, but it still hasn't.
Does anybody have any idea what i need to do to get the head unit to store the settings? At the moment i'm really considering just selling it and buying an OEM one, at least that way i'll get my steering controls back too!!
Phil
OK, this is the ISO block direct from the car...
Yellow Green | Red | White | Grey | Brown | Purple
Black | Red | Blue |Nothing|Nothing| Yellow
The 2nd row of colours is what comes from the head unit.
Found this on 206info, i think i'll try moving the Yellow from HU to White on car ISO.
swapped the yellow and red around on the connector that goes into the head unit, still no difference, on the pug loom theres a earth/ground (green and yellow), an accessory (light blue) and a permanent live (white)
