Anyone with an Arctic Freezer7 Pro?
18 Oct 2002
UK
G'day, I'm wondering if this cooler will fit in my rather slimline case, and hoping a kind owner will go through the hassle of measuring it for me!
I see the height is listed as 126.5mm, I'm wondering if thats the entire height of the whole shebang including the motherboard mounts underneath, or just from the bottom of the actual copper base and up?
I know it's not much of a difference, but want the best cooling I can get in there! Perhaps someone with the cooler can measure from the actual face of the motherboard up to the top of the cooler? So including the socket as well.
Infact that last measurement will be the most usefull!
Ceers!
126.5mm from the copper base to the tip of the heatpipes. The socket probably adds another 10mm.
cheers for that, I guess they measure them all sans clips then, gives a better number I guess seeing as Intel/AMD sockets would be different.
sadly that puts the top of the cooler through my case window! I knew using 10MM thick perspex was a bad idea....
