- 16 Nov 2003
- On the pale blue dot
Hi guys. I have the following HTPC spec:
Silverstone LC-17 case
Intel E2200 with a Scythe Mini Ninja attached
ATI 2400XT passive (for HD decoding)
200GB system disk
500GB data disc
DVD drive
Blu-ray/HD-DVD drive
All Sharkoon fans.
Here is the existing setup:
This idles at around 35 degrees, using Orthos and leaving it at 100% CPU usuage for an hour I ended up with a maximum CPU temperature of 51 degrees. This system is however, quite loud.
Here is what I've changed it to:
Doing the same tests, the system idles at the same 35 degrees, with a maximum temperature of 58 degrees.
Now the system is never going to be running at full clip, the most taxing thing it will ever be doing is playing a Blu-ray, which I'm running at the moment with 15% CPU usage and a core temperature of 38 degrees.
My only concern is that without any 'outtake' I've got a lot of air sitting in the case. Is this arrangement safe in the long term? It is still much cooler than my P4 system, which I could fry my dinner on.
200GB system disk
500GB data disc
DVD drive
All Sharkoon fans.
