http://www.energysavingtrust.org.uk.../types_of_renewables/ground_source_heat_pumps
more than 3 years
and you have a cut off on the size or property that it will work in. Also how much land have you got ( size of Garden ) and do you want it Dug up
I would only suggest fitting GSHP's in brand new properties
( they are also useless with radiators underfloor heating only TBH )
Underfloor heating is far superior to radiators though (I wonder can you use underfloor heating with a standard central heating system?), and it provides cooling in the summer. A geothermal system would complement a standard central heating system normally. You can also get grants of around £1,500 towards the cost.
NP mate
