- 19 Feb 2004
- in a house
Ok, so I am no stranger to overclocking, and in most tests, the only way to truly see whether your overclock is definitely stable seems to be to run Prime95 for a good few hours to make sure you have no errors.
In the past, I have run it and it has immediately failed, although windows and games (for the most part) are ok. For general day-to-day use, and gaming, if my PC doesnt crash - I dont care if it can't run a stupid test for X amount of hours.....
However, I tweaked some settings recently after rebuilding my PC and found that it was in fact unstable - another thing that confirmed this was a windows version of memtest that instantly brought up messages advising me that my RAM had a problem holding any information at all.
So, after a few adjustments and dropping clock speeds back etc and tightening timings - 333 x 9 on the C2Q6600 @1.3v giving me 3ghz and 800mhz on the RAM running at 4-4-4-12 @ 2.0v - the memory program reported no errors.
So, just before going to bed, I thought - why not, ill stick Prime95 on all 4 cores and go to bed, giving it a good 9 hours running time. The morning came, and to my delight, the PC hadnt rebooted, albeit the room was quite toasty, so all seemed well.
However, on closer inspection, the thread it was running on Core2 had failed after 18 minutes of operation. The other 3 were still running fine 9 hours later.
My thoughts are - what does this actually mean? Is the overclock unstable? Could it just have been a hiccup and the overclock is stable?
Once again, I cant see any problems in games, windows is always fine, and any other test I do works ok. I havent re-run Prime95 yet, which I may do later.......
Cheers,
Craig
Cheers,
Craig
