I'm now almost certain that nobody knows what "bad coding" means. Try playing a game that crashes every 2 minutes regardless of hardware config, has rampant memory leaks, gives you 10fps even on its lowest settings etc to see a real example of this.
However trying to save your e-peen machine's face by blaming the magic codez when playing Crysis at higher settings and for some reason or other expecting several hundred FPS is just foolhardy.
No that would be "terrible" coding. When all is said and done, if you have the highest spec rig available today and a year old game STILL runs like arse then you know something is wrong. Sorry to break up your rant a bit there.
