best coolant?
18 Mar 2008
What is the best combination of things to use as coolants. something that picks up the most heat from the waterblock, is it feser, or distilled or dionized water or something else, also which coolant doesn't damage your components if spillage occurs?
Thanks :D
coolant makes next to no difference to performance. I'd go with feser/distilled and PT Nuke etc to stop algae.
Seriously though, almost anything will be fine, try milk.
HAHA! would be so funny if someone tried it. I use Swiftechs own Hydrx coolant. but i think it corroded my Apogee drive as it developed a leak after a month and the res was empty!
no wounder my cpu was 70C after 1 minute
Milk would probably eat through your pipes after a while because of the lactic acid etc - the smell would be pretty bad too coupled with the chunky bits clogging the pump :p
Not very good at my biology but I'm sure you're milk loop would turn into cheese/yoghurt/butter after a while!
