Anyone sit down in the shower?
Looks like im the minority!, kinda guessed i might be!
I think it stemmed from when i used to party a little bit hard and on my morning after i would be totally spaced out. So i would sit on the floor of the shower for a good half hour with a brain clear of any activity :)
I dont like baths because i cant regulate the temperature.. once im in it, i usually get too hot and dont like the faff on of adding enough cold etc.
I recommend you try it if you have a good size cubical, just sit yourself down and its a kinda nice way to chill out :)
I used to, however i'd just doze off and get told off.
I still take a good half an hour in the shower though, sometimes it's just nice to stand there and chill a bit.
maybe the word is "wash" ;)
I think you got half the word right.
I often sit in the shower :)
It can be relaxing to kinda doze for a bit in there :D
At uni (many moons ago now when i was a scallywag) I often used to get in from a night hammered, make straight for my shower, get in fully clothed, and fall asleep. You feel soooo much better when u doze off. I would then wake up at about 6am, when the water went cold, and have no hangover! - Job done!!!
I sat in the shower when I was very ill, couldn't stand up. :(
The water gets cold because it has to go so far, my advice is lower the shower head and crank up the heat or have a bath.
