Q6600 G0 not stable @ 3.3GHz - already at 1.5v
Permabanned
25 Mar 2007
Hi all,
Northbridge: 1.4v
DRAM voltage: 2.1V (Crucial Ballistic PC2 5300 overclocked to 879MHz)
CPU voltage: 1.5V
Loal-line calibration enabled
FSB 366
CPU multiplier 9
Temperatures are fine and it boots. However, it won't handle Prime for more than 5 seconds or so - it just locks up. I am wary of increasing the voltage anymore.
Advice?
Try toning down the clock on your RAM, underclock it to eliminate that as a factor. I personally feel that is causing the problem 667 -> 879 is probably pushing it too hard at higher FSB
I tried 733 (the lowest) and it is still failing.
Note that it is as solid as a rock at 333x9 with the RAM clocked to 800Mhz (1.4v on the CPU).
Which motherboard are you using?
I'd agree with the others in that it's the RAM causing your problems, no way should a Q6600 need 1.5v for 3.3GHz! I'm on 3.2GHz and I've only increased the core by about 0.1v!
Try running a memtest bootable CD, would imagine it'd show the RAM to be at fault pretty quickly.
I have four sticks of RAM (Ballistix PC2-5300). Asus P5KC motherboard. Shall I try increasing the voltage on the RAM (from 2.1V)?
I have NB set to 1.4 already, next step is 1.55v - safe?
I have also tested with just 3 sticks of RAM, still no avail.
You could try a different BIOS if it bothers you, they can be different, but you would be going through a lot of hassle trying to find one thats better. I still say try 2 sticks :p
1.55v should be alright used to run mine at that no issue on my P5K-E.. if you want to test if its a RAM->CPU issue easiest way would be to take 2 sticks out and keep the NB @ 1.4v
If you have an option and havent set it then set the FSB to Northbridge Strap Manually to 333mhz
Also if you have them set the PLL and VTT (FSB Termination Voltages) Manually
Have you set the CPU voltage to 1.5 in BIOS or is that in windows? my mate has a P5KC and gets a ridiculous case of vdrop.. which could be your problem,
We had a right time getting his E6850 from 3Ghz to 3.4Ghz due to the Vdrop. :/
Dont mean to go the other direction to the topic direction, but hypothetically, if chip 'A''s upper voltage limit is 1.5V, and your board 'B' has a 0.1V Vdrop, it is perfectly safe towards the CPU to set the BIOS value at 1.6? Or would the CPU get 1.6V anyway and die a painful death.
Sorry I dont really understand VDrop ^_^
There is vdrop and vdroop. Both different but ultimately the same effect.
From memory vdroop is the difference between your bios setting and your windows voltage at idle.
Vdrop is when your cpu is under load.
You don't want your voltage at windows idle to be more than Intels recommended tbh.
As for your question, Intel states their recommended max voltage is for bios, not after vdrop at idle in windows as, as your pc boots it might spike at the max set in bios.
Hi all,
Northbridge: 1.4v
CPU voltage: 1.5V
FSB 366
CPU multiplier 9
Advice?
same thing happens in prime when i try to push my 6300 past 3.4GHz
its the ram limiting you in my opinion
im looking at upgrading mine to some pc2-8500 soon to give me some more headroom
i think some pc2-6400 modules would help you out
Hi all,
Northbridge: 1.4v
CPU voltage: 1.5V
FSB 366
CPU multiplier 9
Advice?
The latest batch of chips dont seem as good....
I have 2 early Q6600 G0's @ 3.6ghz......but i got another recently for my bro & even on an x48 chipset i could only get to 3.4ghz stable
