Overclocker's 'Primo Basic' ASUS case - It has a strange duct to the CPU? (IMAGES)
I was working on 'Primo Basic' case last night - http://www.overclockers.co.uk/showproduct.php?prodid=FS-037-OK
I noticed on the side panel there was a grill, which had an odd looking duct inside which seemed to end in a funnel/tube leading towards where the heatsink fan is... (It's a couple of cm short of heat sink fan itself)
Is this a new idea so you can put a duct/pipe leading straight from the side of the case to the CPU fan, so air is drawn in from mainly outside the case for it?
Wonder why they don't just put a plastic sheath over this so you can make it shorter/longer to make it reach to the CPU fan?
It looks like something could be fitted that could be slotted on fitted to length then turned and locked into position?
