I last night overclocked my Q6600 in a P5Q Deluxe with a Tuniq Tower
I am @ 1.425 volts but getting too hot in Prime (throttling kicks in after 30 mins)
When idle it is around 40C
Speedfan reports Core 0,1,2,3 @ 75C and rising after 30 minutes of blend.
I was suprised at the jump when stll at relatively low voltage
I have extra tightened all the TTowers screws - there is one I can't get to without motherboard removal - so I may remove the mobi and reapply thermal paste and reseat the Tuniq, the other option is to throttle back the volts and drop the Mhz a bit - anyone got any tips?
I also have a couple of spare fans (2x120mm and 3x80mm) so might have a read through the motherboard manual to see if there is a 3 pin connector for extra's (I'm thinking I could use my free Asus 80mm pointed from the Hard disk cage to blow over the memory+top side of the CPU). If I do this I'll report back with new temps.
Sorry for waffling on - at least I know I can get 3.3 with no problems so I can always drop back to that but you know what us OC'ers are like
