- 19 Oct 2002
- Shakespeare’s County
Shocking how low they can be considering aeroplanes manage over 25mpg.
Per passenger on a crammed sardine can
fit gas turbines to cars and then we'll see what has better fuel economy.
Read the thread?
per passenger...
you're comparing an internal combustion engine with a gas turbine?
the internal combustion engine is probably the least efficient engine ever![]()
No, light aircraft like the Cessna 162 can manage 25mpg.
No I'm comparing a normal combustion engine plane.
The Cessna 182 is capable of cruising at that speed but fuel consumption is in the region of 60 litres per hour at that sort of cruise, even when leaned back at altitude.No, light aircraft like the Cessna 162 can manage 25mpg at 136mph.
A glider can get infinite MPG too
Surely 0mpg? As you put no fuel in!![]()
divide by zero error alert!If you divide something (miles) by a zero denominator (gallons) you get a value of infinity![]()
i did?
