Odd stability issue with new build
31 Mar 2006
I've just finished rebuilding an old PC around a new P35-DS3L board, in an Antec 300 case, and I've got a bit of a stability issue which I think I've identified, but thought it's worth getting a second opinion seeing as it's an odd one.
Rest of the parts are an E6300 with a mild overclock, Thermalright 120 cooler with an arctic cooler fan stuck on it, 4gb of OCZ special ops PC2-7200 ram (4 sticks, not ideal), one F1 750 drive, one samsung dvd-rom, 8800GT at stock clocks, corsair 620W psu. The case has 3 extra yate loons stuck in it as well as the standard 120mm and 140mm exits.
Basically, it slowly overheats over time... But the displayed temps are all rock-bottom, and the CPU cooler's barely warm. All the major components seem fine, with *** exception of the ram- a feel around found some very hot heat sinks. So a wee bit of further investigation, and it looks like the 2 case fans in the rear are cooling the CPU cooler so much that the fan never spins up. As a result, the airflow over the RAM's really, really weak. Or so it seems to me.
Does that sound plausible? There's no chance at all that it's a CPU or GPU overheat here, they're both running cool, and the NB is hot but not too hot. The RAM's running within its stock speed (it's at about 875, it's rated at 900 at 5-5-5-15). But obviously 4 sticks with heat sinks on means they're very crowded.
Assuming I'm right, what should I try next? Put the fan onto constant 7V instead of under mobo control? Seperate ram fans? Or should I just cut my losses on the 4 sticks and sell up, and get a pair of 2gb sticks?
I never expected my build to be thwarted by excessively good cooling ;)
Well I would cut losses and get some new RAM - it's so cheap at the moment it would be silly not to ;) However, whilst from what you've said it does appear to be a RAM temp issue, there are still so many other things that could be causing instability. What are the actual symptoms of the instability? What does the Event Viewer reveal?
what he said.
Symptoms are just a straight BSOD and reset (annoyingly, too fast to see any details of the BSOD).
I wasn't aware of the event viewer til just now- thanks for the tip! Found 3 1001 errors, 1 is definately ram, the other 2 may be. So that does tie in (one is also often linked to a creative audigy card, which I do have fitted but forgot to mention, so I'll keep an eye on that)
I've dropped out 2 sticks and set the fan to run at full whack and the temps are waaaaay down to the touch- so I'll fire on orthos now and see if it recurs
Thanks very much for the help- I'd no idea about the event viewer function til now, that'll be very helpful.
You could try all 4 ram sticks but slack off the timing and check ram voltage to see if that helps improve stability.
This would not be the first mobo to not like 4 sticks of ram
Yeah, I'm coming back to that as probably the best option- may just pop them back on MM and get a pair of 2gbs on general principles, whether it fixes the issue or not it can't be a bad move.
1. Navigate to the Control Panel in Windows XP
2. In the Control Panel window, open System.
3. Advanced tab.
4. Startup and Recovery, Settings
5. locate and uncheck the check box next to Automatically restart.
6. Click OK
7. Click OK
8. From now on, when a problem causes a BSOD, the PC will not automatically reboot.
