Vista Sidebar Gadgets - Drive Info
28 Nov 2005
Scotland
What good sidebar gadgets do you use for Vista?
Also whats a good drive info gadget to display the space etc using icons etc.
I tried to use the Sushi's DriveInfo which seems to be popular however when i do...nothing is displayed? just a blank space on the sidebar!
Drive Meter v1.03
http://thehobbylounge.com/forum/index.php?action=tpmod;dl=item134
Whats new?
- Activity light is working as it should now
- Activity light color selection ( 15 different colors fitting with most status bars)
- Transfer speeds are available when the gadget is extended (click on the status box to extend or check the box inside the settings)
- Taking no ressource (when compared to my previous v1.0)
- Flyout made full transparent a slightly bigger icons ( Click on the activity light to open the flyout!)
- Drive detection code increased ( it will now tell you if you have a removable, dvdwriter or dvdrom drive )
- Mapped and network drive detection is fixed Smiley
- Settings are slighly cleaned up.
- Bugs fixes...
40+ Gadgets http://thehobbylounge.com/forum/index.php?action=tpmod;dl=cat96
I use The Hobby Lounge ones, as recommended by Final8y :)
I can't seem to find them/have access to them on the hobby lounge? You have to be a member or something?
Edit - sorry I do have to register. Being a nubbin ;)
