- 18 Mar 2008
...if I'm using usb speakers?
You only need a decent soundcard if you use the analogue outputs or need some specific feature.
Or have a decent sound system.![]()
No, this doesn't change what I said.
Wrong. If you have a decent sound system, ie Hi-Fi seperates then it deserves a decent soundcard. Although if you use USB speakers then it doesn't matter.
You said nothing about speaker quality.. :-/ What has features and analogue outputs got to do with speaker quality?
