which pc games support xbox 360 pad ?
CSA
CSA
20 Apr 2006
Lancashire
Hi all , ive just ordered a wired 360 pad for my pc and i'd like to know what games are supported
are there any lists anywhere ? :)
Test Drive Unlimited
Rainbow Six Vegas 2
Medal Of Honour: Airborne
Assasins Creed
Maybe GRID (Not sure)
Everything with Games for Windows on the box will support it fully
And almost anything else can be rigged up to use it if you are willing to mess about a little.
Every game I've played that's suited a pad has worked fine, 'Games for Windows' or not. A few that came with native profiles include Spiderman: Friend or Foe (which was a painfully shocking game), GRiD, Lego Indiana Jones, Ratatoullie and Crysis. Some stonkers there. :rolleyes:
Only game ive found not to work we 360 pad is COD4 .....You can get xpadder for it but, just no!....
Assassins Creed doesn't want to map my 360 controller properly for some reason but all the other games i've tried work fine (DMC3, Grid)
Very weird....
All i did was plug it in ?
That's really odd, the buttons are mapping all over the pad for me lol its not even possible to walk in a straight line with it...
I'll try get a screen shot of the default config it gives me at some point when i get chance
Any "Games for Windows" game that supports gamepads, has support for the 360 pad by default (all proper mapped out etc, and some games even change the icons to the correct buttons). A whole bunch of other games also support it, mostly modern.
Do the new Tomb Raiders work with the 360 pad?
Yes, perfectly. I was just playing Anniversary today, and also have Legend installed. Both map the controller perfectly with no settings changes.
Every game I have that needs a controller works perfectly with the Xbox360 controller, even if it's not "Games for Windows".
"Games for Windows" games will simply give better support, it doesn't mean that they're the only games that are supported with the controller.
