First off I must apologise for being quite the R-tard at knowing about RAM. So sry if my question has been asked a million times before (I did do a search but didnt find anything that exactly matched my query).
I've just upgraded my RAM from the following:
"Crucial 2x1GB 240-Pin DIMM PC2-6400 Unbuffered Non-ECC CL4"
to another 2gb of supposedly the same RAM. However, the new 2gb looks a little different to the older 2gb (but the site i ordered it from says its the same as I used to the same stock code). So, I will be having 4 x 1gig sticks in my motherboard which is an Abit IP35 Pro.
Looking on the forum it appears I will probably need to manually change some settings in the BIOS for this upgrade. Is this true? What will I need to change?
The sticker on the RAM quotes the numbers "800mhz 4-4-4-12 2.0V"
So I presume I change the voltage for each stick of RAM to 2.0V?
Not entirely sure what the other numbers relate to and if I need to change anything else?
Thanks for any help guys!
