PC Dosn't shut down?
6 Apr 2004
Bath, UK
This has just started happening, can't think why...
When i click Start > Shut Down
I Dont get the options box appear, just the sand timer, which stays there.
Any ideas.
Probably some bugged process thats stopping it.
Firewall or Anti virus usually. I had trouble with zonealarm before.
Check the event viewer to see what apps and process are running when its trying to shutdown.
Thats a good call,
What was the last app you installed that could well be the problem.
Last app i installed was ermmm Nokia phone stuff (but has worked before when i installed)
After it hangs for a while, it does come up - not sure how long because i left the room. But then when i click shut down, the blue screen comes up with the mouse still on the screen - which you can move?
:S
It's definitely some problem program or process not shutting down correctly.
How about using system restore to go back to a time when you didn't have the problem, then try and isolate the problem program.
