Sapphire HD 4850
Its not hard to put a fan on the accelero, some people may prefer all in one, but I thought most people would prefer the best cooling tbh for lower temps.
i got that bios for my saphhy 4850, overclocks it a little as standard which it handles perfectly fine, although the fan curve the guy has put on it, is taking some time getting used to. These stock coolers get very loud past 46%.
Mine idles at 75 at stock fan speeds but i have a small case and bad airflow, luckily i bought the ASUS 4850 which comes with smart doctor so you can enable smart cooling :)
Those temps are fine for stock cooler. Bung a S1 + 92mm fans on it :cool: It will drop the temps a LOT.
