New Xbox 360 dashboard video
Looks nice, just hope they fix the playlists while playing games and being able to put a game disc in without autoplay kicking in while you're clearly navigating through the dash to do something else.
It looks horrible when using a theme as they still haven't got rid of the big grey slab on the bottom - the theme only appears on the top half. It also looks terribly confusing. There are more menus and slides than ever before!
Is there any mention that you can copy your own videos to the internal hard drive yet? I thought they were implementing that feature but have seen nothing about it.
I'm fairly sure i've read somewhere that you can keep the blades if you prefer them.
Not 100% though :p
No, you can't keep the blades but the entire functionality that was available with the blades is now morphed into the Xbox Guide.
I also gave up half way, lol.
However I like the blades more. I don't think I will like this update coming, will have to resereve judgement until I actually have used it! :)
What do you mean "fix"? Can't you just turn autoplay off :confused:
Oh and for all those "dreading it" there was a big "This is totally optional" at the start of the video :)
The update itself isnt totally optional - he said the avatars and the hard drive install is.
& Dave is talking about something totally different...
The autoplay option is for switching the xbox on and off - Dave means when you insert a disc, it wont automatically play the game if you're busy navigating through menu's - which I agree is a total pita
The Avatars is a grey area, as I understand it future games will use them, so if you do not create one you will get a generic one by default.
rp2000
Yeah I'd heard its optional. Thats good, it does look pretty sweet though!
So what exactly is the point of having a game installed if you can't play it without the disc?
What are the advantages to having this?
Looking forward to this, the avatars look a bit camp but maybe they will change or you can change the stance or whatever.
