Ok, probably a commonly asked question, and I know I want a DSLR and can afford one, but should I get one?
Most of my photography is done whilest mountaineering or climbing. This means every gram of weight is a premium. Also a large camera is likely to live in the top pocket of my bag. Semi accessible but not not as good as my chest pocket for action shots, or to snap without stopping. I guess more protection (adding weight) is needed for a bigger camera too, to stop damage and wetness.
Currently I have a Canon Ixus 850 IS. It's light, tiny, it takes amazing photos without much tweeking. The battery lasts forever, and it's pretty rugged, dealing with abuse and dampness just fine.
However... Whilest the colour saturation of pictures is amazing, the sharpness (especially the edges at 28mm) and the noise are pretty bad. I know that thats the sacrifice you make with such a small camera.
Here's an example:
Wonderful shot, but the lack of sharpness and noise really seem to detract from it as a whole.
So do people think it's worth carrying an SLR and maybe missing a few shots, but getting better shots when I do take them or should I stick with the compact. Also would the weight saving of say a Canon 400D outweigh the partial weather seals of say a 30D.
Here's an example:
. I don't have an issue shooting with prime lenses (your comment of them not being much good for anything is ridiculous) and Pentax supply them in 21mm, 40mm and 70mm versions, so there is a pretty good range available anyway.
. They wouldn't all be on the camera at once
