- 27 Apr 2004
I mentioned a while back in the Why isn't Robot Wars on TV anymore? thread that myself and a few friends would be building a combat robot. Thought I'd make a sort of build log type thing on here in case anyone's interested.
A few details:
Weapon: Top hinged pneumatic flipper
Drive: Two wheel drive, differential steering
Motors: 2x DeWalt 24V drill motors and twin speed gearboxes
Peak power: 4HP
What will hopefully make Fury unique is the power supply; we're going to be using two YUASA 12V 17AH batteries in series for 24V main drive, and will have a third YUASA 12V 17AH battery that can be used in series with the main, to momentarily boost the drive voltage to 36V for extra speed and torque.
The dual voltage drive, direction, and speed will all be controlled by our own DIY motor controller I will be designing, which will provide continually variable speed control in both forward and reverse, at both 24V and 36V, all done with solid state components only (aswell as electronic braking and neutral).
We had hoped to complete the design and build this summer before we all go off to University, but we've all just been too busy to get that much done, so it's now going to be a longer term project - hopefully finished by this time next year.
A picture is worth a thousand words, so with the introduction and description done, here are a few:
10" Tungsten carbide tipped saw we bought for the project. Everything we've used so far (steel wise) was scrap - a few lengths of box section, and a pair of old car ramps will form the frame for bodywork.
Partially completed chassis. This was my first time welding.
Putting the side pieces on.
Putting the side pieces on (again).
Close up.
Close up (again).
Mock up of how it will go together. The bodywork will be welded to the red car ramps, which in turn will be bolted to the chassis so that the entire top can be lifted off for easy access for repairs and maintenance.
Competition wise, if/when we finish it, we hope to enter in Roaming Robots.
Hope this is of interest to some of you on here.
A few details:
Peak power: 4HP
Close up.
Close up (again).
Yeah it would be pretty cool having the saw on the top, except we'd need to buy/build an AC inverter, and... spinning weapons are against the rules.
