Back folding but slightly confused
19 Jan 2006
After a break to get the system watercooled, a busted psu and other time constraints i am back!
Still with the Q6600 and 8800gt.
Q6600 now up an running @ 3.37ghz (more to come hopefully when i have time) and 8800gt overclocked as well.
Installed the cpu client and all appears ok there. New Win SMP client seems a bit strange. 6.22beta one i mean.
It only appears when both one single smp and one single gpu client are running that the cpu client is only fully stretching one core?? I thought they used to do 100% of 2 cores??:confused:
Is there anything else i have missed whilst i've been non-folding (apart from still being hopefully 2nd to a million points before we all killed those pesky pirates!)
EDIT - defo something not right with the cpu client !
Have you included the -smp flag? It's required for the 6.22 client to pull down SMP WUs. Without it you'll just get normal work units.
You're still 2nd, though Yeggstry and I are closing fast :p
not sure - how u do that again??
[20:37:46] *------------------------------*
[20:37:46] Folding@Home PMD Core
[20:37:46] Version 1.03 (September 7, 2005)
[20:37:46]
[20:37:46] Preparing to commence simulation
[20:37:46] - Looking at optimizations...
[20:37:46] - Created dyn
[20:37:46] - Files status OK
[20:37:46] - Expanded 93067 -> 599777 (decompressed 644.4 percent)
[20:37:46]
[20:37:46] Project: 2170 (Run 10, Clone 593, Gen 5)
[20:37:46]
[20:37:46] Assembly optimizations on if available.
[20:37:46] Entering M.D.
[20:37:52] Protein: p2170_lambda_obc_300K
[20:37:52]
[20:37:52] Completed 0 out of 500000 steps (0%)
Right click on the shotycut and choose properties, then in the target line put a space then -smp after the quotation marks (path should like this: "C:\Program Files (x86)\Folding@Home Windows SMP Client V1.01\[email protected]" -smp)
No, I'm not. I have 3 3340 WUs which are dragging me down. Let me speak for myself, I can see what WUs I have...
Tell me about it - had 2 out of 4 instances stuck with those all this week :o
On the plus side the one that just finished was replaced with a 1760 so there may be hope on the horizon for you :)
booyaka, that log shows a standard non-SMP WU - check your shortcut and restart the client :)
No, I'm not. Let me speak for myself, I can see what WUs I have...
I was talking about the last couple of weeks in general; you've made up 100k on him! And I've been playing Oblivion half the day so my output's not been too great either. So it was just a light-hearted comment... never mind, I won't speak out of line again :confused: *gets his head down and folds on*
hmm - well restarted client, deleted the old work folder but still not liking the WIn SMP.
It's EUE'd twice and then just suspended itself. Maybe something to do with the overclock but that was set yesterday and passed a 12 hour prime95 stable run just before i started folding again.
The gpu client is folding away quiet happy and nice to see my name no longer greyed out on the stats!!
I didn't think much of the new SMP client under Vista64 - didn't try going back to the new release of the older client as I went to VMWare and Ubuntu instead (fair bit of hassle getting that working under Vista also though :o)
The GPU client is great - awesome PPD, and with very few exceptions it just works. VMWare is a pain... are you running version 2, or version 1 with driver signing disabled?
booyaka, post your SMP log again with the errors and I'll have a look.
--- Opening Log file [August 31 20:35:37 UTC]
# Windows CPU Console Edition #################################################
Folding@Home Client Version 6.22 SMP Beta2
http://folding.stanford.edu
Launch directory: F:\FAH6.22beta2-win32-SMP-deino
Executable: F:\FAH6.22beta2-win32-SMP-deino\[email protected]
[20:35:37] Configuring Folding@Home...
The program will continue in non-service mode now, working in F:\FAH6.22beta2-win32-SMP-deino.
The next time the computer is starts up, you should see work automatically
continue there. Note that when this service is running, you should not try
to manually run F@H from that directory at the same time.
[20:37:27] - Ask before connecting: No
[20:37:27] - User name: booyaka (Team 10)
[20:37:27] - User ID: 12D0A86B52470D11
[20:37:27] - Machine ID: 1
[20:37:27]
[20:37:27] Work directory not found. Creating...
[20:37:27] Could not open work queue, generating new queue...
[20:37:27] - Preparing to get new work unit...
[20:37:27] + Attempting to get work packet
[20:37:27] - Connecting to assignment server
[20:37:28] - Successful: assigned to (171.65.103.160).
[20:37:28] + News From Folding@Home: Welcome to Folding@Home
[20:37:28] Loaded queue successfully.
[20:37:30] + Closed connections
[20:37:30]
[20:37:30] + Processing work unit
[20:37:30] Core required: FahCore_82.exe
[20:37:30] Core not found.
[20:37:30] - Core is not present or corrupted.
[20:37:30] - Attempting to download new core...
[20:37:30] + Downloading new core: FahCore_82.exe
[20:37:32] + 10240 bytes downloaded
[20:37:32] + 20480 bytes downloaded
[20:37:32] + 30720 bytes downloaded
[20:37:32] + 40960 bytes downloaded
[20:37:32] + 51200 bytes downloaded
[20:37:32] + 61440 bytes downloaded
[20:37:32] + 71680 bytes downloaded
[20:37:33] + 81920 bytes downloaded
[20:37:33] + 92160 bytes downloaded
[20:37:33] + 102400 bytes downloaded
[20:37:33] + 112640 bytes downloaded
[20:37:33] + 122880 bytes downloaded
[20:37:33] + 133120 bytes downloaded
[20:37:33] + 143360 bytes downloaded
[20:37:33] + 153600 bytes downloaded
[20:37:33] + 163840 bytes downloaded
[20:37:33] + 174080 bytes downloaded
[20:37:33] + 184320 bytes downloaded
[20:37:33] + 194560 bytes downloaded
[20:37:33] + 204800 bytes downloaded
[20:37:33] + 215040 bytes downloaded
[20:37:33] + 225280 bytes downloaded
[20:37:33] + 235520 bytes downloaded
[20:37:33] + 245760 bytes downloaded
[20:37:33] + 256000 bytes downloaded
[20:37:33] + 266240 bytes downloaded
[20:37:33] + 276480 bytes downloaded
[20:37:33] + 286720 bytes downloaded
[20:37:33] + 296960 bytes downloaded
[20:37:33] + 307200 bytes downloaded
[20:37:33] + 317440 bytes downloaded
[20:37:33] + 327680 bytes downloaded
[20:37:33] + 337920 bytes downloaded
[20:37:33] + 348160 bytes downloaded
[20:37:33] + 358400 bytes downloaded
[20:37:33] + 368640 bytes downloaded
[20:37:33] + 378880 bytes downloaded
[20:37:33] + 389120 bytes downloaded
[20:37:33] + 399360 bytes downloaded
[20:37:34] + 409600 bytes downloaded
[20:37:34] + 419840 bytes downloaded
[20:37:34] + 430080 bytes downloaded
[20:37:34] + 440320 bytes downloaded
[20:37:34] + 450560 bytes downloaded
[20:37:34] + 460800 bytes downloaded
[20:37:34] + 471040 bytes downloaded
[20:37:34] + 481280 bytes downloaded
[20:37:34] + 491520 bytes downloaded
[20:37:34] + 501760 bytes downloaded
[20:37:34] + 512000 bytes downloaded
[20:37:34] + 522240 bytes downloaded
[20:37:35] + 532480 bytes downloaded
[20:37:35] + 542720 bytes downloaded
[20:37:35] + 552960 bytes downloaded
[20:37:35] + 563200 bytes downloaded
[20:37:35] + 573440 bytes downloaded
[20:37:35] + 583680 bytes downloaded
[20:37:35] + 593920 bytes downloaded
[20:37:35] + 604160 bytes downloaded
[20:37:35] + 614400 bytes downloaded
[20:37:35] + 624640 bytes downloaded
[20:37:35] + 634880 bytes downloaded
[20:37:35] + 645120 bytes downloaded
[20:37:35] + 655360 bytes downloaded
[20:37:35] + 665600 bytes downloaded
[20:37:35] + 675840 bytes downloaded
[20:37:35] + 686080 bytes downloaded
[20:37:35] + 696320 bytes downloaded
[20:37:35] + 706560 bytes downloaded
[20:37:35] + 716479 bytes downloaded
[20:37:35] Verifying core Core_82.fah...
[20:37:35] Signature is VALID
[20:37:35]
[20:37:35] Trying to unzip core FahCore_82.exe
[20:37:36] Decompressed FahCore_82.exe (1683456 bytes) successfully
[20:37:41] + Core successfully engaged
[20:37:46]
[20:37:46] + Processing work unit
[20:37:46] Core required: FahCore_82.exe
[20:37:46] Core found.
[20:37:46] Working on queue slot 01 [August 31 20:37:46 UTC]
[20:37:46] + Working ...
[20:37:46]
[20:37:46]
[20:37:46]
[20:37:46]
[20:37:52]
Folding@Home Client Shutdown.
--- Opening Log file [August 31 22:32:04 UTC]
# Windows SMP Console Edition #################################################
Arguments: -smp
[22:32:04] - Ask before connecting: No
[22:32:04] - User name: booyaka (Team 10)
[22:32:04] - User ID: 12D0A86B52470D11
[22:32:04] - Machine ID: 1
[22:32:04]
[22:32:04] Loaded queue successfully.
[22:32:04]
[22:32:04] + Processing work unit
[22:32:04] Work type 82 not eligible for variable processors
[22:32:04] Core required: FahCore_82.exe
[22:32:04] Core found.
[22:32:04] Using generic mpiexec calls
[22:32:04] Working on queue slot 01 [August 31 22:32:04 UTC]
[22:32:04] + Working ...
[22:32:05]
[22:32:05] *------------------------------*
[22:32:05] Folding@Home PMD Core
[22:32:05] Version 1.03 (September 7, 2005)
[22:32:05]
[22:32:05] Preparing to commence simulation
[22:32:05] - Looking at optimizations...
[22:32:05] - Previous termina- Expanded 93067 -> 599777 (decompressed 644.4 percent)
[22:32:05]
[22:32:05] Project: 2170 (Run 10, Clone 593, Gen 5)
[22:32:05]
[22:32:05] Assembly optimizations on if available.
[22:32:05] Entering M.D.
[22:32:05] 0, Clone 593, Gen 5)
[22:32:05]
[22:32:12] leted 0 out of 500000 steps (0%)
Folding@Home Client Shutdown at user request.
--- Opening Log file [August 31 22:41:59 UTC]
Arguments: -smp
[22:41:59] - Ask before connecting: No
[22:41:59] - User name: booyaka (Team 10)
[22:41:59] - User ID: 12D0A86B52470D11
[22:41:59] - Machine ID: 1
[22:41:59]
[22:41:59] Loaded queue successfully.
[22:41:59]
[22:41:59] + Processing work unit
[22:41:59] Work type 82 not eligible for variable processors
[22:41:59] Core required: FahCore_82.exe
[22:41:59] Core found.
[22:41:59] Using generic mpiexec calls
[22:41:59] Working on queue slot 01 [August 31 22:41:59 UTC]
[22:41:59] + Working ...
[22:41:59]
[22:41:59] *------------------------------*
[22:41:59] Folding@Home PMD Core
[22:41:59] Version 1.03 (September 7, 2005)
[22:41:59]
[22:41:59] Preparing to commence simulation
[22:41:59] - Looking at optimizations...
[22:41:59] - Previous termina- Expanded 93067 -> 599777 (decompressed 644.4 percent)
[22:41:59]
[22:41:59] Project: 2170 (Run 10, Clone 593, Gen 5)
[22:41:59]
[22:41:59] Assembly optimizations on if available.
[22:41:59] Entering M.D.
[22:41:59] Client no longer detected. Shutting down core
[22:41:59] onger detected. Shutting down core
[22:41:59]
[22:41:59] Folding@home Core Shutdown: CLIENT_DIED
[22:47:08] checkpoint files
[22:52:05] Writing local files
[22:52:05] Completed 5000 out of 500000 steps (1%)
[23:02:11] Writing checkpoint files
[23:11:50] Writing local files
[23:11:50] Completed 10000 out of 500000 steps (2%)
[23:17:13] Writing checkpoint files
[23:31:25] Writing local files
[23:31:25] Completed 15000 out of 500000 steps (3%)
[23:32:17] Writing checkpoint files
[23:47:17] Writing checkpoint files
[23:50:54] Writing local files
[23:50:54] Completed 20000 out of 500000 steps (4%)
[00:02:17] Writing checkpoint files
[00:10:18] Writing local files
[00:10:18] Completed 25000 out of 500000 steps (5%)
[00:10:18] Going to send back what have done.
[00:10:18] logfile size: 15171
[00:10:18] - Writing 15691 bytes of core data to disk...
[00:10:18] Done: 15179 -> 2825 (compressed to 18.6 percent)
[00:10:18] ... Done.
[00:10:18]
[00:10:18] Folding@home Core Shutdown: EARLY_UNIT_END
That's getting confused because it's trying to run a non-SMP WU using the SMP software. Looks like the first time you ran the SMP client you ran it without -smp, so it downloaded a normal WU. Now you need to delete the work folder from F:\FAH6.22beta2-win32-SMP-deino and delete the queue.dat file, then start the client again.
Version 1 with driver signing disabled - works most of the time but can get itself in a muddle from time to time - think maybe I need to get the network settings sorted as from time to time I lose sight of one of the machines in FahMon :o
Sorry Mattus, I didn't mean to bite your head off. Was just frustrated at these WUs that really dragged my production down. I was matching you more or less, but from EOC you can see my production has taken a turn for the worse :/
Hopefully that will change today tho, dumped my 2nd 3340 WU and the third should be done today as well. I'm back on the 1920s so bring it on :cool:
No worries :) It's pretty frustrating when you put time/money into folding and get rewarded with crap WUs. I dread waking up to a pair of those 3340s :( Here's to a September full of a2 cores!
i've not even bothered firing up the SMP part any more.
8800gt is doing a grand job on it's own - propelling me towards the 1 million point mark
