is this ok ????
3 Jul 2007
Rochdale/whitworth
K is this a good score on 3dm06
the spec
intel c2d e2060 1.8Ghz over clocked to 3.1Ghz (temps = idel 45c load 68c ish)
GeIL 2GB PC2-6400C5 800MHz Vale Ram (ram is overclocked to 833Mhz)
HD4850 512Meg (stock)
GigBitye p965 DS3.
vista 32bit
res 1280*1024
THE SCORE
the cpu speed will be causign you to get that sort of score.
you could put a 4870 in your pc and it would make not much difference on 3dmark06.
try downloading and running the free run of 3dmark vantage that will show you the difference.
this is the score i get using 3DMark Vantage
res was 1280*1024 and preset to performance
is it ok or is it underperforming ?????
i would say thats a bit low
my 8800 Ultra scores 6956 in the graphics score on performance preset in vantage.
Yours is 6387.
I would have thought a 4850 would have been faster than my 8800 Ultra which is jsut an overclocked 8800 GTX really
3d mark 06 does not score new ati cards as well as it should do compared to other cards. you need vantage to properly bench the new ati cards.
Yours is 6387.
thats what i think. It **** be a lot faster then your 8800 Ultra
even if the cpu is bottlenecking
tryed comparing the score on 3dmark vantage site and cant find a similar system to compare
