Hi,
looking into nitrous for my MR2 to get some extra power, good idea? or better off finding another way?
Cheers
Yea it's a sound idea, best to run a progressive controller though as it's much, much kinder to the engine/drivetrain and in the end allows you to run larger shots.
Get a 2nd hand Wizards of Nitrous (WON) system and have a play!
Be wary though - the larger the shot, the sooner you expend the contents of the bottle. The more you get addicted to the increase, the quicker the bottle empties. The larger the bottle, the more it costs to fill.....
I.e. a standard sie 11lb bottle costs around 40 quid to get filledYou can empty that with ease in a day's drag racing (or less, depending on shot) - so bear that in mind.
All I can say is you mentalist!
Out of interest, could twin turbos be better? IIRC some imports had twins? Stupidly expensive to do though I guess.
the way i use my car (weekend toy) i will be filling it up every weekend
where you get them filled?
i wouldnt, youll get used to it, get a bigger turbo etc tbh
People forget that the main benifit of it is that you have that additional power when you need it - and still retain the behavior and economics of the standard powerplant. No decreased economy, no driveability issues and so on.
How often do you need full power acceleration, for example.
Plus, if needed, you can remove it all with ease.
There is a legal requirement for commercial vehicles to display a suitable sticker but this does not apply to private vehicles, which are not even obliged to display a green compressed gas sticker. However, displaying such a warning sticker might well be advantageous to you and the emergency services if you were to be involved in any kind of accident, as this would inform them that you were carrying a container of compressed oxidiser.
o
From my perspective the extra load a nitrous shot could put on a car could be too much for it to handle and as such you could do more damage to it than improve performance.
as in make so much torque that it twists the chassis![]()
