oh dear, I can see this thread turning sour, the Z5500's have been mentioned, this is the end
On a lighter note, if the OP has a budget of £699, he is obviously willing to spend that much on his speakers, so you might as well get the best you can for that price rather than buy something less than half the price.
Are these new ones you are going to buy? If so you can use any standard speaker cables on the new revision, i chucked on some expensive stuff my dad had left over from building his surround sound system and cut them to length. The old revision (with the fixed cables) gives around 5m for the rears and 2m for the fronts.
