How do you know which voltage to set?
3 Dec 2004
Hi all,
I've never really understood the workings of a PSU.
Is there a way to tell in bios if my system is getting enough power? How much power should you give LDT, Chipset and Dram?
I can view the current voltage each component is getting but how do I know if its enough? For example, i can see my chipset is using 1.56v and I have it set to 1.56 so I know it cannot use anymore - but what if it needs more?
I hope all that makes sense,
Any help appreciated.
