I just purchased a Powercolour 4850 and have been running a few stress tests. Everything runs fine at 780core and 1125mem (Accelero S1 + 2x92mm and 1.2v) except for FurMark which blank screens at anything over 720core after a few mins.
ATItool runs 780/1125 fine (max temp 47deg)
Crysis runs 780/1125 fine (30+ mins and 50deg max)
GRID runs 780/1125 fine (30+mins and 48deg max)
3DMark06 780/1125 fine (45deg max) Linky
FurMark will only run 720/1125 (30+mins and 58deg max temp)
So, Furmark gets my temperatures 20% higher than anything else at lower core clocks. Even if I lower the memory to stock it still will not allow higher GPU clocks. I guess it is giving the Shaders a pounding, but is there anything else that can stress a GPU more?
edit: Idle temps are 31deg with the S1.
