- 20 Apr 2008
- West Midlands
yesterday i was having problems where by my pc wasn't shutting down.
adding that with the problems of my bios i was getting quite annoyed but i solved the problem and thought i'd post what i found/did incase anyone else has had similar problems when shutting the pc down.
basically i went into:
Start:
Control Panel:
Power Options:
Edit Plan Settings:
then i clicked on Change advance power settings.
withing here there is an option of the harddrive and when to turn it off.
this was set to 20mins so i turned it back to 0 and my computer shut down first time!!!!!!
has anyone else had this or can shed any light as to why it happend
Start:
Control Panel:
Power Options:
Edit Plan Settings:
