This is an old school case from the days of thick aluminium, small fans and emptying your wallet to afford the bleedin thing when it came out.
So to begin I had an old 1fan Radiator waterchill watercooling kit that some may recognise
It had been sitting around for ages not being used cos I was too chicken/lazy to play with watercooling.
So I stripped down the 201
And started taping it up ready for cutting:
I had planned to put the rad in the roof because, well there isn't anywhere else to put it on these things without really hacking into them, remember these are the 80mm fan years.
Anyway after removing the fan and mesh from the blowhole in the top I found I had to cut these little lugs off that it had all been screwed into, so I said fairwell to a few dremel disks and got to work.
Here she is upside down with a couple of those pesky lugs cut off.
It had been sitting around for ages not being used cos I was too chicken/lazy to play with watercooling.So I stripped down the 201
