BACKSTORY
been collecting watercooling stuff over the last few months
got most of the standard stuff already
pump/res combo
alphacool rad + fans
dangerden 1/2" tubes [couldnt get masterkleer]
primochill coils
its all been sitting around for a while
reason being is that the case i want still isnt in the country yet so i am not rushing with the water system
its only cooling the cpu
to be honest its more of an aesthetic plan but hoping to be able to clock higher too
picking up an EK supreme clear cpu block soon
QUESTIONS
with me having the bulk of the stuff already i have been looking at barbs
i need 6 in total
i was thinking that compression fittings look pretty good - and should do the job well on 1/2" tubing
what are your thoughts on this?
im not keen on the idea of plastic clips etc
also will two compression fittings fit on the EK supreme clear cpu block that i am getting?
also - read so many conflicting reports on coolant [i guess its personal preference] but would i be ok just using a bottle of F1?
or should i use an alternative
thanks in advance for the advice
rjkoneill
pump/res combo
primochill coils
QUESTIONS
i need 6 in total
rjkoneill
