What to believe?
I have a lapped Thermalright Ultra-120 stuck on the chip, with a 120mm Scythe fan. The case (Lian Li PC-7) is air-cooled to hell (nor not really, as hell is a hot place).
I've felt the base of the cooler whilst running, and it is cold to the touch. I do not see how the cores can be 40deg+ idle.
I used to run a lapped Q6600 G0, and Coretemp would report that idles at around 23degrees. I don't see why a lower voltage, smaller process chip would idle at double this temperature in the same kit.
(Mobo: ASUS P5Q-E).
Cheers
(Mobo: ASUS P5Q-E).
Cheers
cool
