i`m overclocking my asus p5e3 and core 2 duo 3 ghz e8400 and have hit a ceiling at 450 fsb which produces a clock speed of 4050 mhz, after that it gets a bit unstable....the core voltage is 1.384 but i don`t seem to be able to change it in the bios, i`ve turned off a lot of auto systems and spread spectrums and as much manual as possible, pcie is @ 100 mhz, i`m trying to change the voltage but although is sais it has changed it doesn`t show on the cpuz test......
i`m also having problems with my memory, running 2 mb of ocz 1333 ddr3 in 2 modules and if it gets around 900 mhz the whole system gets unstable, over 1000 and it just won`t start at all, it should get up around 1333.....the timings are 5 5 5 15 but if i increase them it won`t start then either, i had major problems in loading the os to start with until i reduced the freq to around 800, then it would load the os and boot properly, increase it to it`s proper running speed and you get nothing......
anyway, i`m going to try and load some screenshots, i`ll be back soon.....
kris
kris
